Archicad C++ API
Accesses the "height of opening" in the dimension's text
Miha Nahtigal
I'm looking for a way to access the height of opening in text of dimension info and add there some text (in addition to the text that already there).
Adding 3 pictures to show what I mean
Adding Configuration image, and before and after images
Thanks
Windows 11, Visual Studio 2019, ArchiCAD 26, C++
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Viktor Kovacs
On sections there is a special element type called API_SectElemType. This is the section representation of an elem. You can get the original elem guid by accessing the parameters of the section element. Something like this:
API_Element element = {};
element.header.guid = sectionElementGuid;
ACAPI_Element_Get (&element);
APIGuid originalElemGuid = element.sectElem.parentGuid;
// now the originalElemGuid contains the real element guid
Viktor Kovacs
Miha Nahtigal
Great. Thank you.
