‎2013-04-18
10:03 PM
‎2023-08-02
03:20 PM
Doreena Deng
‎2013-04-22 12:53 PM
LesWoolsey wrote:I assume you want the parameters derived from the GDL door object? If so, you need to look in a memo structure linked to the element. This data is not automatically loaded with the rest of the element for efficiency, so it has to be loaded independently. There are 2 ways to approach this:
I can see it has an ID, it has a setting that says whether its load bearing, external etc. I can also see that there are Materials and other parameters associated with the door. How do I get at these via API. I tried listing the parameters and it always tells me the parameter count is 0.
‎2013-04-22 06:42 PM
‎2013-04-22 09:46 PM
LesWoolsey wrote:The 'A' parameter is simply the first item in the array, i.e.
the memo object has a value for param called "A". But where are the rest of the parameters?
(*memo.params)[0]The 'B' parameter would be:
(*memo.params)[1]...and so on. You could get the total number of parameters by dividing the memory allocation by the size of the parameter structure:
UInt32 totalParams = BMGetHandleSize(memo.params) / sizeof(API_AddParType);
‎2013-04-23 05:23 PM
‎2013-04-23 06:44 PM
‎2013-04-23 11:59 PM
LesWoolsey wrote:The data is stored in different locations - some it is in the element, some in the parameters, and some in the IFC properties/attributes. And yes, the new functions in AC16 will allow you to extract the IFC properties. However, the IFC properties may not relate to anything you see in the model, e.g. the materials of a door. Objects cannot use (or even see) IFC properties, so materials will largely be driven by parameters.
it doesn't seem to relate in any obvious way to the building. For example, if I select a door and check its selection properties, I get a whole lot of properties, For example, under Tags & Categories & I can see, ID, Structural Function, Position etc. But I don't see any of that in the list I get back in the memo params. I also don't get back the door's type. I can't see where the various materials and finished are defined. My goal is to be able to see the various properties that get exposed in the IFC file
‎2013-04-24 12:34 AM
‎2013-04-24 02:20 PM
LesWoolsey wrote:Sure, I'll contact you by email. The best starting point from this forum is PM first - then you don't need to expose your email address. Spammers trawl these forums for target addresses unfortunately.
Is there a way to communicate off the message board?
