We value your input!
Archicad C++ API
Add-on error
RAFD
Hi, I just want to ask what I should do if my archicad 27 always crashes while opening an add-on made by our company? It's working perfectly in AC26. I manage to upgrade the add-on for AC27 but when I try to open it, it crashes.
LChen
Hi, If API27 example addon works on your PC without any problem, then I'd suggest you to check VC project file settings carefully to see whether everything (include header/lib/etc. file path) refer to new API27 Dev Kit and try again.
HTH.
There can be a lot of different reasons for this. I'd try the following approach to debug your Add-On:
  1. Remove the Add-On from the Add-On Manager
  2. Restart Archicad
  3. Attach a debugger to Archicad
  4. Set breakpoints at the start of the CheckEnvironment, RegisterInterface and Initialize functions
  5. Load the Add-On and step through the code to see when it crashes
  6. Alternatively check the stack trace when it crashes
Hope that helps,
Bernd
