‎2005-01-21
04:22 PM
‎2024-09-24
10:07 AM
Doreena Deng
‎2005-01-21 09:21 PM
TomWaltz wrote:A) You can add a custom panel to the wall settings dialog, but I didn use it. There is API example.
I know in GDL it's simple, but I am digging around trying to find out if (A) I can add a panel to the Wall Settings menu and (B) assign the information to the walls in a project.
Any thoughts?
‎2005-01-21 10:26 PM
‎2005-01-22 12:07 AM
‎2005-01-22 04:18 AM
‎2005-01-22 07:37 AM
TomWaltz wrote:sorry for the basic Qs but how does that interface/work with Archicad
Codewarrior.
‎2005-01-22 08:42 AM
TomWaltz wrote:You need to create RO folder. I dont remember exactly, but it seems inside MAKE.MAC folder. The RO forder is the destination for the GS GRC compiler where it will put a compiled resources and icons.
For some reason, I am getting errors when I compile that one
‎2005-01-22 02:10 PM
‎2005-01-24 04:02 AM
TomWaltz wrote:Yes, thanks, Oleg. Somehow, I hadn't explored that sample yet.
Oleg
thanks for the tip, I had just found that Panel Test myself.
For some reason, I am getting errors when I compile that one.... maybe Akos can shed some light?
‎2005-01-24 09:48 AM
Karl wrote:Hi all,TomWaltz wrote:Another question for Akos ... it compiles fine on XP, but the panel for the Materials Attributes dialog does not appear. Panels in the Infobox and Wall Settings dialog show up fine. If I change the code to use the Linetype dialog, it shows up just fine. I wonder if the Materials problem is a functionality issue from 6.0 to 6.1 and the LW panels? Or perhaps me being blind and just not seeing it?
Thanks,
