2015-01-22
03:44 PM
2023-08-01
01:52 PM
Doreena Deng
if (e.GetSource() == &m_btnTest) { typedef IKlass* (__cdecl *iklass_factory)(); HINSTANCE dll_handle = ::LoadLibrary(TEXT("BCWebSDK.dll")); if (!dll_handle) { } // Get the function from the DLL iklass_factory factory_func = reinterpret_cast<iklass_factory>(::GetProcAddress(dll_handle, "create_klass")); if (!factory_func) { ::FreeLibrary(dll_handle); } IKlass* instance = factory_func(); std::vector<int> info = instance->data(); // This is what I need from dll and it works fine instance->destroy(); ::FreeLibrary(dll_handle); }
2023-02-28 09:47 PM
Hi! Were you able to fix this error? I'm getting the same exception when using libcpr (DLLss are in Archicad.exe folder, and LIBs are properly linked at "Aditional Dependencies").
