Hoa Tu
ArchiCAD Semiramis Component has stopped working.Please help
Hi all,
When I tried to compile the GRC files, it comes up the error message and stops the compiling process. I have tried to re-install ArchiCAD 15 and even try to re-install the Microsoft Visual Studio 2005, the error still comes up.
Any one has experience about this problem, your help is much appreciated.
Regards,
Hoa Tu
ArchiCAD 15,
Windows 7 Utimate 32 bit
3 Replies 3
Hi Hoa Tu,
Could you give us some details about the error ? What is written in the build output ?
Regards,
Siwar
Hoa Tu
The build message is as followed:
1>------ Build started: Project: Element_Test, Configuration: Release Win32 ------
1>Compiling the non-localized GRC file...
1>Project : error PRJ0019: A tool returned an error code from "Compiling the non-localized GRC file..."
1>Build log was saved at "file://c:\D Drive for API Projects\API Projects\HT\Element_Test\Release\BuildLog.htm"
1>Element_Test - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Also I have attached the screen capture of the Semiramis Error dialog box.
Thanks.
FYI:
Semiramis was the code name for this ArchiCAD version.
