Archicad C++ API
Archicad 29.0.1 API Developer Kit Released - but you might not need it
Daniel Kassai
Graphisoft Moderator
Dear Add-On Developers,
Archicad 29.0.1 has been released, so we took the opportunity to release some minor API changes in a related Devkit
Check out the New API features in Archicad 29 to see what has changed.
If you are not using the mentioned class in your add-on, then you have nothing to do. Your add-on built with the AC29.3000 DevKit will still work fine with AC29.0.1.
I recommend subscribing to our Releases page so you get instantly notified when a new Devkit is released.
Happy coding!
Daniel
Daniel Kassai
Principal Product Manager at Graphisoft
Hi Bernd!
Regarding the issue with the railing, Ákos Somorjai have followed up on the original thread.
Let's discuss the details there.
Best regards!
Daniel
Daniel Kassai
Hi Daniel,
Thanks for the release! The fix for the ResConv crash is very appreciated 🙂
Do you have any information on when to expect fixes for moving railing vertices and for which AC versions?
https://community.graphisoft.com/t5/Archicad-C-API/How-to-move-railing-vertices/m-p/678308#M10595
Kind regards,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Hi Bernd!
Best regards!
Daniel
Daniel Kassai
