2018-07-26
12:52 PM
2022-12-06
01:29 PM
Daniel Kassai
Solved! Go to Solution.
2018-08-10 05:00 PM
API_Attribute composite; BNZeroMemory (&composite, sizeof(API_Attribute)); composite.header.typeID = API_CompWallID; composite.header.index = element.wall.composite; GSErrCode err = ACAPI_Attribute_Get (&composite); if (err == NoError) { API_AttributeDefExt compDefs; BNZeroMemory (&compDefs, sizeof (API_AttributeDefExt)); err = ACAPI_Attribute_GetDefExt (API_CompWallID, composite.header.index, &compDefs); if (err == NoError) { // enumerate the parts for (short ii = 0; ii < composite.compWall.nComps; ++ii) { API_CWallComponent& part = (*compDefs.cwall_compItems)[ii]; part.buildingMaterial; /**< index of the building material */ part.fillThick; /**< absolute thickness of the component in m */ } // after you modified the thickness you can save it using ACAPI_Attribute_ModifyExt } ACAPI_DisposeAttrDefsHdlsExt (&compDefs); }If you have any further questions, feel free to ask me!
2018-08-10 05:00 PM
2018-08-13 01:27 PM
