Archicad C++ API
Can I make a composite wall with c++ api?
LeeJaeYoung
If possible, what example files can I study?
AC27 on window 11
Joel Buehler
i did not test it by myselft but i would recommend:
- The Maze Generator Example shows how to create a wall from the ACAPI_Element_GetDefaults
- It is possible to change evrything in a default element with the ACAPI_​Element_​ChangeDefaults API Call
- waht you want to do is maybe burried in the API_Element > API_WallType > API_AttributeIndex composite struct
im having allways problems to get all setings from structs right, so that the API does not give me a error back. waht helped me a lot is to print out values. so if i had to do your task, i would start from the maze generator example and start to change the default settings one by one until the wall is the desired composite. i think you also need to write  a function to retrive the composite attribute index of your desired composite.
Viktor Kovacs
What @Joel Buehler proposed is a good starting point, but don't forget to change the modelElemStructureType member to API_CompositeStructure.
LeeJaeYoung
thank you. ^^
I'll do more study and post more questions.
AC27 on window 11
