Archicad C++ API
Cannot build Element_Test Add-On from Examples (AC 22 Windows)
Hello!
When trying to build the example Element_Test (MDID_APICD_ElementManager) with Ctrl+Shift+B I get several errors by Visual Studio coming from an xlocale file (see attachment). I do not have this problem with building any other of the Example add-ons. Is this example buggy or am I doing something wrong?
MSVC version: 14.13.26128 (attachment)
Edit: I now also updated my Dev environment to the latest VS version (15.9.2) and MSVC version 14.16.27023, but the problem remains.
Thanks,
- Dan
Akos Somorjai
Hi Dan,
You have to use the Visual Studio 2015, or Visual Studio 2017 with the VS2015 toolset (see http://archicadapi.graphisoft.com/working-in-visual-studio-2017).
We'll switch to VS2017 in the ARCHICAD 23 API
Regards, Akos
Akos Somorjai
Hi Dan,
Regards, Akos
poco2013
Mentor
Just wondering if VS2017 Community for MAC could be used on a MAC for the 23 API instead of XCODE??
Gerry
dfintha
The macOS version of Microsoft Visual Studio does not support C++ development.
As such, it's improbable that it will be supported for add-on development.
Best regards,
DƩnes
