YourQS
Cannot generate example projects for AC27
I am trying to set up the CMake environment for AC27 example projects
I have followed the web example of how to set up the CMake environment, but without success:
Clone the repo with
git clone (message won't allow me to insert html) --recurse-submodules
Run the build script
python Tools/BuildAddOn.py --configFile config.json --acVersion 26 27
I get the following output:
Downloading API.Development.Kit.WIN.26.7000.zip
Extracting API.Development.Kit.WIN.26.7000.zip
Downloading API.Development.Kit.WIN.27.3001.zip
Extracting API.Development.Kit.WIN.27.3001.zip
[WinError 2] The system cannot find the file specified
This indicates that I have downloaded the repo fine, because it finds the tools folder and the Python script. The problem is I have no idea what "the file specified" is, because there is no log file. Running the script in verbose mode gives me this:
import 'tarfile' # <_frozen_importlib_external.SourceFileLoader object at 0x000001BB2FD06D50>
Can anyone help with getting the example projects set up?
1 Solution
YourQS
Hi, Chris has helped me with this issue and it is now resolved.   The problem was I didn't have a path to CMake.exe
Go to post
4 Replies 4
Archein
Have you ever add your python to the path in enviroment variables.
YourQS
Hi, yes I have.
Hiromichi Shinkawa
Hi, Could you login from Archicad API site and download Devkit from web?
YourQS
