Archicad C++ API
Change Navigator View property using "APINavigator_ChangeNavigatorViewID"
Nayan
I am try to change the Navigator Item "overrideCombination" and the type defination is " GS::uchar_t overrideCombination[API_UniLongNameLen];".
Using the "ACAPI_Override_GetOverrideCombination(combination, nullptr);" I am retrieving override combination "name" which is of type GS::UniString.
So whenever I trying to set the "API_NavigatorView.overrideCombination" with combination name it's showing error as it's trying to convert GS::UniString to GS::uchar_t.
Any suggestion how can I convert Unistring to GS::uchar_t and also how can I change "overrideCombination" item of the Navigator Item?
Viktor Kovacs
From the "Override_Test" Add-On:
GS::UniString newCombinationName = "Override Test Add-on Combination Name";
GS::ucsncpy (view.overrideCombination, newCombinationName.ToUStr (), API_UniLongNameLen);
Viktor Kovacs
Nayan
Thank you Viktor Kovacs.
