Column wrapped finish
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-07-12
03:53 AM
2024-09-24
09:47 AM
Doreena Deng
2016-07-12
03:53 AM
Is there a way of getting the surface area of this wrapped finish on column? (Construction method: Wrapped)
The first thought that came to mind is the veneer surface area. But when I get the value, it is zero (0.00). This means that this finish is not considered as the column veneer.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-07-12 10:23 AM
2016-07-12
10:23 AM
it would also be nice to be able to hang on to extremity of plating
AMD Ryzen 5950x
AMD RX 9070xt
AC28
AMD RX 9070xt
AC28
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-07-19 09:26 PM
2016-07-19
09:26 PM
Yes this is a couple of ways you can build a schedule that extracts the surface area from the column data, or you can go to the WINDOW (drop down menu)/Palettes/Element Information (near the bottom) and you should be able to get the surface area from that Palette.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
