yahavsa
Compilation error when open a new Archicad 26 API template on VS2019
Hi there!
I'm just trying to open a completely new Archicad 26 add-on on VS2019, located in the "Examples" folder.
When I build the project for the first time (without coding anything) I get the following errors:
Error (active)	E1696	cannot open source file "RS.hpp"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Support\Inc\APIdefs_Interface.h	26
Error (active)	E0020	identifier "APIAny_NeigIDToElemTypeID" is undefined	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	156
Error (active)	E0135	class "API_Elem_Head" has no member "typeID"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	174
Error (active)	E0135	class "API_Elem_Head" has no member "typeID"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	180
Error (active)	E0020	identifier "APIAny_GetElemTypeNameID" is undefined	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	422
Error (active)	E0135	class "API_ElemSearchPars" has no member "typeID"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	562
Error (active)	E0135	class "API_Elem_Head" has no member "typeID"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	569
Error (active)	E0135	class "API_ElemSearchPars" has no member "typeID"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	569
Error (active)	E0135	class "API_SectElemType" has no member "parentID"	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c	600
Warning	MSB8064	Custom build for item "RFIX.WIN\test2.rc2" succeeded, but specified dependency "c:\program files\graphisoft\api development kit 26.3000\examples\test2\test2\build\x64\debug\ro\elemicons.grc.rc2" does not exist. This may cause incremental build to work incorrectly.	test2	C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets	241
Error	C1083	Cannot open include file: 'RS.hpp': No such file or directory	test2	C:\Program Files\Graphisoft\API Development Kit 26.3000\Support\Inc\APIdefs_Interface.h	26
I would like to mention three kinds of these errors:
1.
Should I manually insert this header?
2. For the elemicons.grc.rc2 warning I have followed the attached link below but I couldn't figure it out
https://community.graphisoft.com/t5/Developer-forum/Translate-API-from-24-to-25-Missing-File/td-p/32...
3. It looks like many of the compilation errors are related to the new API features in ArchiCAD 26. I assume that all of these changes should be included in the ArchiCAD 26 Add-On Templates so I guess that i miss something.
Will appreciated any help or suggestions.
Thanks!
3 Replies 3
SamuraiMen
Try inserting the above header manually, in my case it fixed the problem. It is possible that this is specific to the ArchiCAD 26 API, by the way, missing something here  is a fairly common situation that many of us face.
Yeojin
Hi, I'm experiencing the same issue. Have you found a solution?
rosedec
