‎2023-09-03 10:20 AM
Hi there!
I'm just trying to open a completely new Archicad 26 add-on on VS2019, located in the "Examples" folder.
When I build the project for the first time (without coding anything) I get the following errors:
Error (active) E1696 cannot open source file "RS.hpp" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Support\Inc\APIdefs_Interface.h 26
Error (active) E0020 identifier "APIAny_NeigIDToElemTypeID" is undefined test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 156
Error (active) E0135 class "API_Elem_Head" has no member "typeID" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 174
Error (active) E0135 class "API_Elem_Head" has no member "typeID" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 180
Error (active) E0020 identifier "APIAny_GetElemTypeNameID" is undefined test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 422
Error (active) E0135 class "API_ElemSearchPars" has no member "typeID" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 562
Error (active) E0135 class "API_Elem_Head" has no member "typeID" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 569
Error (active) E0135 class "API_ElemSearchPars" has no member "typeID" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 569
Error (active) E0135 class "API_SectElemType" has no member "parentID" test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Examples\test2\test2\Src\APICommon.c 600
Warning MSB8064 Custom build for item "RFIX.WIN\test2.rc2" succeeded, but specified dependency "c:\program files\graphisoft\api development kit 26.3000\examples\test2\test2\build\x64\debug\ro\elemicons.grc.rc2" does not exist. This may cause incremental build to work incorrectly. test2 C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets 241
Error C1083 Cannot open include file: 'RS.hpp': No such file or directory test2 C:\Program Files\Graphisoft\API Development Kit 26.3000\Support\Inc\APIdefs_Interface.h 26
I would like to mention three kinds of these errors:
1.
Should I manually insert this header?
2. For the elemicons.grc.rc2 warning I have followed the attached link below but I couldn't figure it out
3. It looks like many of the compilation errors are related to the new API features in ArchiCAD 26. I assume that all of these changes should be included in the ArchiCAD 26 Add-On Templates so I guess that i miss something.
Will appreciated any help or suggestions.
Thanks!
‎2023-09-06 12:08 PM - edited ‎2024-02-24 09:20 AM
Try inserting the above header manually, in my case it fixed the problem. It is possible that this is specific to the ArchiCAD 26 API, by the way, missing something here is a fairly common situation that many of us face.
‎2024-01-23 05:13 AM
Hi, I'm experiencing the same issue. Have you found a solution?
‎2025-01-01 01:50 AM
