Archicad C++ API
SOLVED!
How to build Add-on in AC27
pphamt
Hello @All,
I am new to C++ and the ArchiCAD API in general.
I've been learning how to create a .sln file from a CmakeList.txt following the instructions I've found in our group. Honestly, I've followed the steps closely, but still can't manage to build the final product, which is the add-on .apx file. I have some questions and really need your help:
  1. When I installed Visual Studio (VS), both VS 2019 and VS 2022, fulfilling the requirements recommended by the site. After that, I proceeded to install the ArchiCAD API (I'm using AC27). I chose all the requirements during installation, but when I open VS 2019 and VS 2022, I can't find the Archicad Add-Ons Template. What should I do to resolve this?
  2. After downloading archicad-addon-cmake, I followed the steps described in this article https://community.graphisoft.com/t5/Documentation/developing-an-add-on-on-c/m-p/395814#M61448, but when I reached step 9 in the image by "Joel Buehler," I couldn't complete building my .apx file. It gave me the following error:
          What should I do to fix this error, or how can I build the Archicad add-on project?
Of course, I am still trying to resolve these two issues I've asked you about, but if I could get more help from you, I would really appreciate it.
Thank you!
1 ACCEPTED SOLUTION
Solution
Viktor Kovacs
I recommend using this as a starting point:
https://community.graphisoft.com/t5/Knowledge-Base/How-To-Set-up-your-Add-On-development-environment...
Now we have a python script that does all the steps above.
5 REPLIES 5
Joel Buehler
hehey pphamt.
Just to be clear, when you are at step 9, you where succsessfull in creating the *.sln correct?
Best Regards
Joel
Solution
Viktor Kovacs
Hi Joel Buehler,
I was able to create the *.sln and then proceeded to build the file but encountered an error.
I tried a different method and successfully built the .apx file.
Thank you
Hi Viktor Kovacs,
Thanks for your support
Very cool.
I recommend you link the blog of the developer site to this knowlege base. information is now kinda all over the place.
https://archicadapi.graphisoft.com/getting-started-with-archicad-add-ons
VS
