2024 Technology Preview Program
Archicad C++ API
Create a dialog with Japanese.
Hi.
I create a dialog with Japanese. I have a problem.
Are there some methods?
Thanks.
leilei
Hi!When you make a compilation error, put a space after the japanese character.I compiled it in this way with Chinese Version.Maybe this can help you.
5 REPLIES 5
Akos Somorjai
Did you start from the HelloWorld example on the blog? Which version of the devkit do you use?
Best, Akos
Hi Akos.
I use visual studio 2017 and API Development Kit 22.3004. when I replaced "hello" with japanese it got an error.
leilei
Akos Somorjai
Could you please try to set your system locale to English? My guess is that ResConv doesn't work well on other systems.
Thanks, Akos
Thanks leilei. I have resolve my problem
