The access violation when create material attribute
Hi.
The access violation error occuers when I create a material attribute.
my code is
API_AttrTypeID typeID = API_MaterialID;
API_Attribute		attrib;
	API_AttributeDefExt	defs;
	BNZeroMemory(&attrib, sizeof(API_Attribute));
attrib.header.typeID = typeID;
	strcpy(attrib.header.name, u8"玻璃 - 蓝色");
	err = ACAPI_Attribute_Get(&attrib);
	if (err == NoError) {
		err = ACAPI_Attribute_GetDefExt(typeID, attrib.header.index, &defs);
		if (err == APIERR_BADID) {
			BNZeroMemory(&defs, sizeof(API_AttributeDefExt));
			err = NoError;
		//能见度100
		attrib.material.transpPc = 100;
			strcpy(attrib.header.name, name.ToCStr().Get());
			err = ACAPI_Attribute_Create(&attrib,nullptr);
		ACAPI_DisposeAttrDefsHdlsExt(&defs);
5 Replies 5
Akos Somorjai
Please use attrib.header.uniStringNamePtr Instead of attrib.header.name, because the .name is limited in length:
GS::UniString attrName (u8"玻璃 - 蓝色");
attrib.header.uniStringNamePtr = &attrName;
and instead of strcpy(attrib.header.name, name.ToCStr().Get()); use:
attrib.header.uniStringNamePtr = &name;
Best, Akos
Best, Akos
According to your method,the problem also occuers.
Ralph Wessel
Best, Akos
I notice you've changed the call for creating the material to ACAPI_Attribute_CreateExt and you're passing a API_AttributeDefExt parameter. Materials don't use API_AttributeDefExt, so perhaps you should be passing just nullptr for that parameter?
Ralph Wessel BArch
Central Innovation
Akos Somorjai
Here's the code that works for me:
	GS::UniString name (u8"能见度100");
	API_Attribute attrib = {};
	API_AttributeDefExt defs = {};
	GSErrCode err = NoError;
	GS::UniString attrName(u8"玻璃 - 蓝色");
	//strcpy(attrib.header.name, u8"玻璃 - 蓝色");
	err = ACAPI_Attribute_Get (&attrib);
	if (err == NoError)
		err = ACAPI_Attribute_GetDefExt (typeID, attrib.header.index, &defs);
			err = NoError;
		//能见度100
		if (err == NoError)
			//strcpy(attrib.header.name, name.ToCStr().Get());
			err = ACAPI_Attribute_CreateExt (&attrib, &defs);
	return;
I think the main problem was calling ACAPI_Attribute_Create instead of ACAPI_Attribute_CreateExt.
Best, Akos
Thanks.
The code don't work for me.
API_Attribute attrib={};
API_AttributeDefExt defs={};
GS::UniString materialName(u8"玻璃 - 蓝色");
attrib.header.uniStringNamePtr = &materialName;
        BNZeroMemory( & defs, sizeof(API_AttributeDefExt));
        err = NoError;
    //能见度100
        GS::UniString attrName(u8"界线");
        err = ACAPI_Attribute_CreateExt( &attrib, &defs);
The same problem also occurs.
The version of Archicad is 22 and the version of vs is 2015.
