2019-12-03
01:15 PM
2022-09-29
09:54 AM
Daniel Kassai
API_AttrTypeID typeID = API_MaterialID; API_Attribute attrib; API_AttributeDefExt defs; BNZeroMemory(&attrib, sizeof(API_Attribute)); attrib.header.typeID = typeID; strcpy(attrib.header.name, u8"玻璃 - 蓝色"); err = ACAPI_Attribute_Get(&attrib); if (err == NoError) { err = ACAPI_Attribute_GetDefExt(typeID, attrib.header.index, &defs); if (err == APIERR_BADID) { BNZeroMemory(&defs, sizeof(API_AttributeDefExt)); err = NoError; } //能见度100 attrib.material.transpPc = 100; if (err == NoError) { strcpy(attrib.header.name, name.ToCStr().Get()); err = ACAPI_Attribute_Create(&attrib,nullptr); } ACAPI_DisposeAttrDefsHdlsExt(&defs); }
2019-12-03 02:43 PM
GS::UniString attrName (u8"玻璃 - 蓝色"); attrib.header.uniStringNamePtr = &attrName;and instead of strcpy(attrib.header.name, name.ToCStr().Get()); use:
attrib.header.uniStringNamePtr = &name;Best, Akos
2019-12-04 02:08 AM
Akos wrote:According to your method,the problem also occuers.
Please use attrib.header.uniStringNamePtr Instead of attrib.header.name, because the .name is limited in length:
2019-12-04 10:41 AM
DevJeer wrote:I notice you've changed the call for creating the material to
2019-12-04 05:57 PM
{ GS::UniString name (u8"能见度100"); API_AttrTypeID typeID = API_MaterialID; API_Attribute attrib = {}; API_AttributeDefExt defs = {}; GSErrCode err = NoError; GS::UniString attrName(u8"玻璃 - 蓝色"); attrib.header.typeID = typeID; attrib.header.uniStringNamePtr = &attrName; //strcpy(attrib.header.name, u8"玻璃 - 蓝色"); err = ACAPI_Attribute_Get (&attrib); if (err == NoError) { err = ACAPI_Attribute_GetDefExt (typeID, attrib.header.index, &defs); if (err == APIERR_BADID) { err = NoError; } //能见度100 attrib.material.transpPc = 100; if (err == NoError) { attrib.header.uniStringNamePtr = &name; //strcpy(attrib.header.name, name.ToCStr().Get()); err = ACAPI_Attribute_CreateExt (&attrib, &defs); } } ACAPI_DisposeAttrDefsHdlsExt(&defs); return; }I think the main problem was calling ACAPI_Attribute_Create instead of ACAPI_Attribute_CreateExt.
2019-12-05 02:20 AM
API_AttrTypeID typeID = API_MaterialID; GSErrCode err = NoError; API_Attribute attrib={}; API_AttributeDefExt defs={}; attrib.header.typeID = typeID; //strcpy(attrib.header.name, u8"玻璃 - 蓝色"); GS::UniString materialName(u8"玻璃 - 蓝色"); attrib.header.uniStringNamePtr = &materialName; err = ACAPI_Attribute_Get(&attrib); if (err == NoError) { err = ACAPI_Attribute_GetDefExt(typeID, attrib.header.index, &defs); if (err == APIERR_BADID) { BNZeroMemory( & defs, sizeof(API_AttributeDefExt)); err = NoError; } //能见度100 attrib.material.transpPc = 100; if (err == NoError) { //strcpy(attrib.header.name, name.ToCStr().Get()); GS::UniString attrName(u8"界线"); attrib.header.uniStringNamePtr = &attrName; err = ACAPI_Attribute_CreateExt( &attrib, &defs); } ACAPI_DisposeAttrDefsHdlsExt(&defs); }The same problem also occurs.
