‎2004-08-19
06:13 AM
‎2023-08-07
12:17 PM
Doreena Deng
‎2004-08-19 06:29 AM
lciscon wrote:I haven't done it, so don't have any code to share ... The Element Manager example project's Element_Basics.cpp file has a lot of sample calls to ACAPI_Element_Create (but no slab). The only reference to API_SlabType in the example source files is in this same example's Element_Modify.cpp file.
Is there some sample code that demonstrates *creating* a slab element?
‎2004-08-23 05:38 PM
‎2004-08-24 12:32 AM
lciscon wrote:It's difficult to say at what point your code is failing without more information. Perhaps you could describe your slab creation in pseudo-code?
...I am having a problem creating a slab "from scratch" (rather than modify an existing slab element).
...but no matter what I do I get a APIERR_BADPOLY error out of the create call.
Initialise an API_Polygon structure (nSubPolys, nCoords, nArcs)
Allocate handles for the relevant fields of an API_ElementMemo structure (vertexIDs, coords, parcs, pends)
For each polygon (perimeter, then holes) {
For each vertex in the current polygon {
Fill in the vertex coordinate (coords)
Fill in the vertex ID (vertexIDs - optional)
If the vertex is the end of an arc
Fill in the arc end details (parcs)
Fill in the polygon end details (pends)
Make sure you allocate handles for the memo structures, not pointers. Contact me privately if you're still getting bogged down and I'll take a quick look at your source.
