2004-06-28 09:25 PM - last edited on 2023-08-07 12:20 PM by Doreena Deng
2004-06-29 12:17 PM
Skywalker wrote:I hope I understand your question, but the header files for VBElemDialog are in the API Dev Kit at Support/Modules/VBElemDialogs.
...there are all header files for VBElemDialog?!
Skywalker wrote:This works OK for me.
While working with panel test example, i've got trouble. Infobox with custom panel works, but:
1) defaults for the element are not changed while using eyedropper
Skywalker wrote:Yes, I've seen the same. I don't know if this is a bug in the example code or a flaw in the API. As I said above, documentation may be the key to the problem - without it, there is no way to know for certain. This problem completely disables the Wall tool settings dialog and the Materials dialog, and often crashes ArchiCAD too.
2) when I add menu in my addon, customm panel is dissapearing when calling this menu
2004-06-29 09:30 PM
