Archicad C++ API
Custom icons become blurry on a higher-than-100% scale
szonjabalega
I'm using .svg type icons in custom Add-ons. If I set the scale of the screen to a higher value than 100%, the custom icons become blurry, however, Archicad's built-in icons stay sharp (even when my icons are the same as Archicad's).
Is there a way to have sharp custom icons using higher scale?
1 REPLY 1
Hiromichi Shinkawa
Hi, maybe you need to check the naming of the .svg file. The pixel of your .svg should be put after the name like below:
Ofline_22x22.svg. Let me send you a sample .svg for your reference.
HTH.
