We value your input!
Archicad C++ API
Customize ArchiCAD UI elements
Can, I change the style of some elements of UI using ArchiCAD API? For Example set color for button background or text. If it's possible, can you provide me a link\small example or anything that can help me with that issue?
1 REPLY 1
Akos Somorjai
No, you can't, the dialog manager doesn't allow such modifications. It tries to adjust to the system color scheme, though..
For example, on macOS you can turn on Dark Mode in the Experimental settings.
Best, Ákos
