kency
Downloading an image for surface creation from a URL
In order to create surface through the plugin we would like to fetch the texture image from a given URL. How can we download the image through ArchiCAD C++ code?
5 Replies 5
Miha Nahtigal
You can use cUrl lib or built in HTTP classes.
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
kency
Any options within the DevKit library? Since we are getting linker error in Windows OS when using curl.h
Found an example to GET json response in Communication_ClientTest but nothing downloads a file.
clientConnection->SetTimeout (requestTimeout);
clientConnection->Send (request);
clientConnection->Receive (response);
Akos Somorjai
Please look at the `Do_DownloadWeatherData()` example in Goodie_Functions.cpp.
Best, Akos
kency
Hello @Akos Somorjai , Just another question on the Do_DownloadWeatherData.
  1. What does DBPrintf do? Where can I check the output
  2. The URL seems to be not working in the provided example.
Akos Somorjai
`DBPrintf ()` prints its output to the debugging window/console, you can safely ignore that.
The URL is just an example, feel free to submit data to any other website.
Best, Akos
