Archicad C++ API
Downloading an image for surface creation from a URL
kency
In order to create surface through the plugin we would like to fetch the texture image from a given URL. How can we download the image through ArchiCAD C++ code?
5 REPLIES 5
Miha Nahtigal
You can use cUrl lib or built in HTTP classes.
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Any options within the DevKit library? Since we are getting linker error in Windows OS when using curl.h
Found an example to GET json response in Communication_ClientTest but nothing downloads a file.
clientConnection->SetTimeout (requestTimeout);
clientConnection->Send (request);
clientConnection->Receive (response);
Please look at the `Do_DownloadWeatherData()` example in Goodie_Functions.cpp.
Best, Akos
kency
Hello @Akos Somorjai , Just another question on the Do_DownloadWeatherData.
  1. What does DBPrintf do? Where can I check the output
  2. The URL seems to be not working in the provided example.
`DBPrintf ()` prints its output to the debugging window/console, you can safely ignore that.
The URL is just an example, feel free to submit data to any other website.
Best, Akos
