Archicad C++ API
GSErrCode ACAPI_Goodies ( APIAny_RunGDLParScript
Hi - I am trying to issue the following command from my C++ plugin:
APIAny_RunGDLParScriptID,
API_Elem_Head* elemHead,
UInt32 mask
My element is an Object, so the code is:
						BNZeroMemory(&tElem2, sizeof(tElem2));
						tElem2.header.guid = GSGuid2APIGuid(element.GetElemGuid());
						GSErrCode err = ACAPI_Goodies(APIAny_RunGDLParScriptID, &tElem2.header, (void*)APIElemMask_FromFloorplan);
However this function is returning error code returned is 0x8106006a. Does anyone know why this would be pls?
Thanks
Paul
Akos Somorjai
UInt32 mask
Thanks
Paul
Hi Paul,
That error code means APIERR_BADDATABASE: that API call can be executed only if any of the 2D window is in front.
Best, Ɓkos
Thanks Akos - that resolved my issue.
Paul
