Archicad C++ API
GSModeler2DImp.lib missing from AC28 SDK
pkinnane
As per the title.  How can I get this file please? It is in the AC27 SDK.
Thanks
Paul
LChen
Please try to use the following LIB instead of 'GSModeler2DImp.lib' to see whether you can pass the link.
GSModelerImp.LIB
HTH
LChen
GSModelerImp.LIB
HTH
pkinnane
That resolves the link issue.  Thank you.
Paul
