mcbabo
Get Materials of Multi-layer components from current selected Wall
I want to extract the materials of a wall I have currently selected
I only know that I get the selected elements with this code (i guess)
GS::Array<API_Neig> walls;
GSErrCode err = ACAPI_Selection_Get(nullptr, &walls, false, true, API_InsidePartially);
kuvbur
	API_Element					element = {};
	API_ModelElemStructureType	structtype = {};
	API_AttributeIndex			constrinx = {};
	double						fillThick = 0;
	BNZeroMemory(&element, sizeof(API_Element));
	element.header.guid = elemGuid;
	err = ACAPI_Element_Get(&element);
	if (err != NoError) {return err;}
structtype = element.wall.modelElemStructureType;
		if (structtype == API_CompositeStructure) constrinx = element.wall.composite;
		if (structtype == API_BasicStructure) constrinx = element.wall.buildingMaterial;
		fillThick = element.wall.thickness;
API_Attribute						attrib;
		API_AttributeDef					defs;
		BNZeroMemory(&attrib, sizeof(API_Attribute));
		BNZeroMemory(&defs, sizeof(API_AttributeDef));
		attrib.header.typeID = API_CompWallID;
		attrib.header.index = constrinx;
		err = ACAPI_Attribute_Get(&attrib);
		err = ACAPI_Attribute_GetDef(attrib.header.typeID, attrib.header.index, &defs);
		for (short i = 0; i < attrib.compWall.nComps; i++) {
			/// you code for (*defs.cwall_compItems)[i].buildingMaterial, (*defs.cwall_compItems)[i].fillThick
		ACAPI_DisposeAttrDefsHdls(&defs);
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
mcbabo
Thanks for your code, but could you please explain the functions of every line. I am very new to the API, so I don't understand all of it.
