Archicad C++ API
Get all wall composites
Emkave
Good day to everybody. I have a struggle with retrieving the whole data about wall composites that exist in an Archicad project.
Here is the empty Archicad project:
and here is the list of wall composites:
I will be really glad if somebody tells me a way how to get all of the composites without passing an element or guid or any other data to the API. I just want to make a code that would return me the list of all existing wall composites.
Thank you in advance!
13 REPLIES 13
Thank you very much for the correction of the topic's placement
Hi Emkave,
This code prints the composite names to the session report (works for AC27+):
ACAPI_Attribute_EnumerateAttributesByType (API_CompWallID,
    [](API_Attribute& compAttr)
    ACAPI_WriteReport (compAttr.header.name, false);
For more details about handling attributes or how to do this for older AC versions you can check the "Attribute_Test" example project in the respective API DevKits.
Or feel free to ask more for more details.
Best,
Bernd
Hello. Thank you for the reply. Is there a function for archicads of versions 26 and below?
Something like this should work in <=AC26 (not tested):
API_AttrTypeID typeID = API_CompWallID;
API_AttributeIndex num = 0;
GSErrCode err = ACAPI_Attribute_GetNum (typeID, &num);
if (err != NoError) { return err; }
for (API_AttributeIndex id = 1; id <= num; ++id) {
  API_Attribute attr{};
  attr.header.typeID = typeID;
  attr.header.index = id;
  GS::UniString tmpUniString;
  attr.header.uniStringNamePtr = &tmpUniString;
  err = ACAPI_Attribute_Get (&attr);
  if (err == APIERR_DELETED || err == APIERR_BADINDEX) { continue; }
  ACAPI_WriteReport (tmpUniString, false);
Setup info provided by author
