Archicad C++ API
Getting the directory of the current Archicad file?
Hello
Is there a way to get the directory of the current Archicad file we are working on?
Thanks in advance!
I don't have a working code sample to hand, but something roughly along the following lines should work;
API_ProjectInfo projectInfo;
ACAPI_Environment(APIEnv_ProjectID, &projectInfo, 0);
if (projectInfo.location != nullptr) {
	IO::Path path;
	projectInfo.location->ToPath(&path);
The variable path will hold the whole pathname.
Ralph Wessel BArch
Central Innovation
7 REPLIES 7
Are you talking about a teamwork project and its libraries ?
What's your aim ?
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
You can use APIEnv_ProjectID method to get the current project info.
API_ProjectInfo projectInfo = {};
GSErrCode err = ACAPI_Environment (APIEnv_ProjectID, &projectInfo);
if (err != NoError)
	return GS::EmptyUniString;
if (projectInfo.untitled) // not saved yet
if (!projectInfo.teamwork) {
	GS::UniString directoryOfTheProjectStr;
	IO::Location projectLocation = *projectInfo.location;
	projectLocation.DeleteLastLocalName ();
	projectLocation.ToPath (&directoryOfTheProjectStr);
	return directoryOfTheProjectStr;
This is quite straight forward. You just use ACAPI_Enviroment function. API_SpecFolderID is a struct with different key locations to choose form. I'm not sure how it works in Teamwork but I assume that It might be the same since IO:: Location handles both local and net locations.
	IO::Location folderLoc;
	API_SpecFolderID specID = API_ApplicationFolderID;
	ACAPI_Environment(APIEnv_GetSpecFolderID, &specID, &folderLoc);
if (err != NoError)
Tried, it gave a bunch of numbers instead of path..
I think that projectinfo.projectpath should do it for me maybe?
Update:
I am unable to get projectpath from some reason. It doesn’t print it and I don’t know how to cast it to string.
My aim is to get the path of the current ARCHICAD file I’m working on as a string..
My code (seems not to work):
GS::UniString GetCurDir(){
API_ProjectInfo pj={};
ACAPI_Environment(APIEnv_ProjectID, &pj);
GS::UniString p=*pj.projectPath;
ACAPI_WriteReport(ā€œ%sā€,true,p);
return p;
	IO::Path path;
Ralph Wessel BArch
Central Innovation
Your code is fine. What probably caused a problem is ACAPI_WriteReport. You can print GS::String and UniString directly without %s
		API_ProjectInfo pj = {};
		GS::UniString p = *pj.projectPath;
		GS::UniString n = *pj.projectName;
		ACAPI_WriteReport(p, true);
		ACAPI_WriteReport(n, true);
Ralph wrote:
working code sample
Tested. This code works.
It’s just doesn’t print, I use the same code as you do.
Windows 10, ARCHICAD 21.
Update:
It finally worked with Ralph’s great code!
But I’m unable to get a sub string with substr (want to remove the name of the file)
Update 2: succeed to remove the name when using the projectName from location (getlaslocalname).
Thanks everyone!
