Getting the directory of the current Archicad file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-07-25
11:36 AM
2022-10-05
01:23 PM
Daniel Kassai
Is there a way to get the directory of the current Archicad file we are working on?
Thanks in advance!
Solved! Go to Solution.
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-25 11:21 PM
API_ProjectInfo projectInfo;
ACAPI_Environment(APIEnv_ProjectID, &projectInfo, 0);
if (projectInfo.location != nullptr) {
IO::Path path;
projectInfo.location->ToPath(&path);
The variable Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-25 11:42 AM
Are you talking about a teamwork project and its libraries ?
What's your aim ?
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-25 12:31 PM
API_ProjectInfo projectInfo = {};
GSErrCode err = ACAPI_Environment (APIEnv_ProjectID, &projectInfo);
if (err != NoError)
return GS::EmptyUniString;
if (projectInfo.untitled) // not saved yet
if (!projectInfo.teamwork) {
GS::UniString directoryOfTheProjectStr;
IO::Location projectLocation = *projectInfo.location;
projectLocation.DeleteLastLocalName ();
projectLocation.ToPath (&directoryOfTheProjectStr);
return directoryOfTheProjectStr;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-25 12:32 PM
IO::Location folderLoc; API_SpecFolderID specID = API_ApplicationFolderID; ACAPI_Environment(APIEnv_GetSpecFolderID, &specID, &folderLoc);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-25 02:32 PM
Tibor wrote:Tried, it gave a bunch of numbers instead of path..
You can use APIEnv_ProjectID method to get the current project info.API_ProjectInfo projectInfo = {}; GSErrCode err = ACAPI_Environment (APIEnv_ProjectID, &projectInfo); if (err != NoError) return GS::EmptyUniString; if (projectInfo.untitled) // not saved yet return GS::EmptyUniString; if (!projectInfo.teamwork) { GS::UniString directoryOfTheProjectStr; IO::Location projectLocation = *projectInfo.location; projectLocation.DeleteLastLocalName (); projectLocation.ToPath (&directoryOfTheProjectStr); return directoryOfTheProjectStr; }
I think that projectinfo.projectpath should do it for me maybe?
Update:
I am unable to get projectpath from some reason. It doesn’t print it and I don’t know how to cast it to string.
My aim is to get the path of the current ARCHICAD file I’m working on as a string..
My code (seems not to work):
GS::UniString GetCurDir(){
API_ProjectInfo pj={};
ACAPI_Environment(APIEnv_ProjectID, &pj);
GS::UniString p=*pj.projectPath;
ACAPI_WriteReport(“%s”,true,p);
return p;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-25 11:21 PM
IO::Path path;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-26 10:27 AM
Tomer1 wrote:Your code is fine. What probably caused a problem is ACAPI_WriteReport. You can print GS::String and UniString directly without %s
API_ProjectInfo pj = {};
GS::UniString p = *pj.projectPath;
GS::UniString n = *pj.projectName;
ACAPI_WriteReport(p, true);
ACAPI_WriteReport(n, true);
Ralph wrote:Tested. This code works.
working code sample
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-28 09:24 AM
Windows 10, ARCHICAD 21.
Update:
It finally worked with Ralph’s great code!
But I’m unable to get a sub string with substr (want to remove the name of the file)
Update 2: succeed to remove the name when using the projectName from location (getlaslocalname).
Thanks everyone!
