Help using ACAPI_Element_Change to change Door's "info"
I'm needing help to change the element.door.openingBase.info of all doors. I've been able to use this API function to change a Wall's info but for some reason no luck with Doors
API_Element element, mask;
Int32 nElem;
GSErrCode err;
char newID[256];
bool *suspGrp;
char msgText[256];
err = ACAPI_OpenUndoableSession ("Create Door Unique IDs");
err = ACAPI_Environment (APIEnv_IsSuspendGroupOnID, &suspGrp, "", "");
/* suspend group mode */
if (suspGrp==false)
err = ACAPI_Element_Tool (NULL, 0, APITool_SuspendGroups, "");
BNZeroMemory (&element, sizeof (API_DoorType));
err = ACAPI_Element_GetNum (API_DoorID, &nElem);
for (Int32 k = 1; k <= nElem; k++)
element.header.typeID = API_DoorID;
element.header.index = k;
err = ACAPI_Element_Get (&element);
if (err == NoError) {
sprintf (newID, "%s%d", "Door ", k);
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_OpeningBaseType, info);
CHCopyC(newID, element.door.openingBase.info);
//CHCopyC(element.door.openingBase.info, msgText);
//DGAlert (DG_INFORMATION, "Unique IDs", msgText, "", "OK","", "");
err = ACAPI_Element_Change (&element, &mask, NULL, 0, true);
//err = ACAPI_Element_Change (&element, NULL, NULL, 0, true);
if (err) {
WriteReport_Err ("Doors-Create Unique IDs:ACAPI_Element_Change", err);
err = NoError;
ACAPI_CloseUndoableSession ();
3 Replies 3
Akos Somorjai
Hi Bianca,
Please set the mask differently:
			ACAPI_ELEMENT_MASK_SET (mask, API_Element, door.openingBase.info);
			CHTruncate (newID, element.door.openingBase.info, sizeof (element.door.openingBase.info));
Hope this helps, Akos
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Bianca,
You have few mistakes in your code, let me correct them:
Correction wrote:
BNZeroMemory (&element, sizeof (API_Element));
Correction wrote:
ACAPI_ELEMENT_MASK_SET (mask, API_DoorType, openingBase.info);
And I suggest you to don't use old typeID+index identification (it's deprecated and in API18 it will be deleted), please use Guids!
Here is your fully corrected code:
GS::Array<API_Guid>	elemList;
Int32				nElem = 0;
GSErrCode			err = NoError;
char				newID[256];
bool				*suspGrp;
char				msgText[256];
if (err)
	WriteReport_Err ("ACAPI_OpenUndoableSession failed", err);
if (err)
	WriteReport_Err ("APIEnv_IsSuspendGroupOnID failed", err);
if (suspGrp == false) {
	if (err)
ACAPI_Element_GetElemList (API_DoorID, &elemList);
for (GS::Array<API_Guid>::ConstIterator it = elemList.Enumerate (); it != NULL; ++it) {
	element.header.guid = *it;
		sprintf (newID, "%s%d", "Door ", ++nElem);
		CHCopyC (newID, element.door.openingBase.info);
		if (err) {
			err = NoError;
Best Regards,
Tibor
Thank you so much for your help. I learnt a few things from this
