Archicad C++ API
How can I get the enumType and parameter meaning of the control in DG_Test Example?
e.g How can I get the supported control type in Archicad API e.g Button and Icon,so on ?
Akos Somorjai
Most of those can be found in the Dialog Manager documentation in the SDK.
Best, Akos
Akos Somorjai
Best, Akos
Best, Akos
I can't find the Dialog Manager document in the SDK. e.g https://archicadapi.graphisoft.com/documentation
Thanks
Best, Akos
I have found the document. Thank you very much
