Linh
How can I hide or show layers by name?
How to hide or show the ESC layer as shown in the image below
Akos Nagy
Hi Linh,
You have to change the bit of APILay_Hidden in the attr.header.flags attribute to get the desired result.
If you always want to show or hide the layer then use the proper branch of the commented solution.
		GS::UniString attrName = *attr.header.uniStringNamePtr;
		if (attrName == "Structural - Bearing") {
			/* change the bit to the opposite in case if you need a one-way solution
			const bool isHiddenLayer = attr.header.flags & APILay_Hidden;
			if (isHiddenLayer) {
				attr.header.flags &= ~APILay_Hidden;
			} else {
				attr.header.flags |= APILay_Hidden;
			// change the bit to the opposite in one line
			attr.header.flags ^= APILay_Hidden;
			ACAPI_Attribute_Modify (&attr, nullptr);
Kind Regards,
Ákos
