2023-12-19
07:22 PM
2024-09-17
12:42 PM
Doreena Deng
How to hide or show the ESC layer as shown in the image below
2023-12-21 02:46 PM
Hi Linh,
You have to change the bit of APILay_Hidden in the attr.header.flags attribute to get the desired result.
If you always want to show or hide the layer then use the proper branch of the commented solution.
GS::UniString attrName = *attr.header.uniStringNamePtr;
if (attrName == "Structural - Bearing") {
/* change the bit to the opposite in case if you need a one-way solution
const bool isHiddenLayer = attr.header.flags & APILay_Hidden;
if (isHiddenLayer) {
attr.header.flags &= ~APILay_Hidden;
} else {
attr.header.flags |= APILay_Hidden;
// change the bit to the opposite in one line
attr.header.flags ^= APILay_Hidden;
ACAPI_Attribute_Modify (&attr, nullptr);
Kind Regards,
Ákos
