How export API_LibPart GSM on computer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Thursday - last edited Thursday
I successfully create a GSM object in Archicad Library, but I don't find a way to export it (or directly create it) on my computer.
Currently, I set the API_LibPart.location in the embeddedLibrary. I tried to set the location on a computer folder and it doesn't work (I get an error -2130312314), I suppose I need to create it in Archicad before exporting it, am I correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thursday
I dont understood your issue exactly, so just a reply about the error code.
See ErrorCodes page of API documentation.
Error -2130312314 means APIERR_NESTING "The API function is not reentrant. Nesting occurred."
I think it is not location issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Friday
- last edited
yesterday
Hello and thanks for the reply.
I've the error -2130313215 the first time I execute my code, then -2130312314 all the next time in the same Archicad instance.
The base of my code come from Speckle connector for Archicad, their methods GetLocation() and CreateSubFolder() work fine to create a library part in the embedded library, it failed when I try to set a Windows path. Source code: https://github.com/specklesystems/speckle-archicad/blob/release/3.0.0/AddOns/Speckle/Sources/AddOn/C...
The code I tried:
API_LibPart libPart;
BNClear(libPart);
BNZeroMemory(&libPart, sizeof(API_LibPart));
libPart.typeID = APILib_ObjectID;
libPart.isTemplate = false;
libPart.isPlaceable = true;
//Location part
IO::Location* loc = new IO::Location();
loc->Set(GS::UniString("D:\\Test")); //The path I want
libPart.location = loc;
CHCopyC("{57B7C584-5C0D-11D6-A0D8-036F034B6791}-{00000000-0000-0000-0000-000000000000}", libPart.parentUnID); // General Stair subtype
GS::ucscpy(libPart.docu_UName, L("Test LibPart")); //library part name
ACAPI_LibraryPart_Create(&libPart); //This method return the error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Friday
Hi
Is this all your code for test ?
PS:
LibPart creation is a building process, starts by ACAPI_LibraryPart_Create and ends by ACAPI_LibraryPart_Save.
LibPart's sections are created between them.
Like in Sparcle's LibpartBuilder::CreateLibPart method.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Friday
Tried the your code above.
But added ACAPI_LibraryPart_Save to avoid -2130312314 error.
It works for me (although it wasn't AC28).
If I change drive letter to non-existent on my PC, I got -2130313215 error.
May be you dont have "D" drive.
