2009-06-18
11:33 AM
2023-08-03
05:07 PM
Doreena Deng
2009-06-18 05:54 PM
/* Version resource - uses strings defined in the localizable resource file 'VERS' { "Your Company" "Copyright © Your Company 2008" "Your Add-On" 1.00 1.00 "ArchiCAD" 12.0 " (12)" } */Above, it says 'uses strings defined in the localizable resource file', but in fact, if you remove the comment marks, the syntax above is for defining the entire VERS resource right there.
'VERS' { COMPANY_STR COPYRIGHT_STR FILEDESC_STR 1.20 1.20 "ArchiCAD" 9.0 }where I defined the macros in the localized grc:
@#define COMPANY_STR "Archispectives LLC" @#define COPYRIGHT_STR "Copyright © Archispectives LLC 2004" @#define FILEDESC_STR "Provides shortcut key access to individual display options."The idea of the localized resource file for defining the strings is simply for easier translation for muli-language versions.
2009-06-19 09:29 AM
equilibrium wrote:Karl has given all the correct steps for adding version info, but I suspect you are trying to overcome the failure of ArchiCAD loading the add-on.
"The file is either not an Add-On or an outdated one that cannot be used with this ArchiCAD version."
How I must to specify version info correct?
2009-06-19 10:13 AM
2009-07-08 12:34 PM
2009-07-08 12:37 PM
santi wrote:Just include the version resource as Karl described above.
I have another question: How do I add the info to the properties of .apx file? I'm on Windows and all the add-ons I've found on internet has it.
2009-07-08 10:52 PM
Ralph wrote:I didnt realize that it was commented outsanti wrote:Just include the version resource as Karl described above.
