Archicad C++ API
SOLVED!
How to call and place a GDL element with API functions?
Archein
Hi everyone, I have some problems with the method to place a GDL object. Should I use ACAPI_​Element_​Create function?
1 ACCEPTED SOLUTION
Solution
Mihaly Palenik
Hello,
yes you can use ACAPI_Element_Create to place a GDL element. First you have to set API_Element's object data member (API_ObjectType). object.libInd data member identifies gdl element. To determine library index by its name you can use ACAPI_Libpart_Search.
1 REPLY 1
Solution
Mihaly Palenik
Hello,
