Archicad C++ API
SOLVED!
How to copy the texture from Embedded Library
sxs
Hi,everyone:
  I need these pictures, how to copy them from Embedded Library?
1 ACCEPTED SOLUTION
Solution
sxs
void DuplicateTexture()
	ModelerAPI::Model model;
	auto err = ACAPI_Sight_GetSelectedSightModel(model);
	if (err != NoError)
		return;
	GS::Int32 texture_count = model.GetTextureCount();
	for (GS::Int32 i = 0; i < texture_count; i++)
		if (!model.IsTextureUsed(ModelerAPI::AttributeIndex(ModelerAPI::AttributeIndex::TextureIndex, i)))
			continue;
		ModelerAPI::Texture texture;
		model.GetTexture(ModelerAPI::AttributeIndex(ModelerAPI::AttributeIndex::TextureIndex, i), &texture);
		if (texture.GetPixelType() != ModelerAPI::Texture::ARGBPixelType)
			continue;
		Int32 pixel_x_size = texture.GetPixelMapXSize();
		Int32 pixel_y_size = texture.GetPixelMapYSize();
		Int32 pixel_size = texture.GetPixelMapSize();
		ModelerAPI::Texture::ARGBPixel* pixel = new ModelerAPI::Texture::ARGBPixel[pixel_size];
		texture.GetPixelMap(pixel);
		//save bitmap
			IO::Location fileLocation;
			IO::fileSystem.GetSpecialLocation(IO::FileSystem::TemporaryFolder, &fileLocation);
			fileLocation.AppendToLocal(IO::Name(texture.GetName()+".jpg"));
			std::string filePath;
			GS::UniString filePath_uni;
			fileLocation.ToPath(&filePath_uni);
			filePath = filePath_uni.ToCStr();
			int ow = pixel_x_size;
			int oh = pixel_y_size;
			int n = 4;
			unsigned char* odata = (unsigned char*)malloc(ow * oh * n);
			for (size_t w = 0; w < pixel_x_size; w++)
				for (size_t h = 0; h < pixel_y_size; h++)
					odata[(w * pixel_x_size + h) * n]	= pixel[w * pixel_x_size + h].red;
					odata[(w * pixel_x_size + h) * n+1] = pixel[w * pixel_x_size + h].green;
					odata[(w * pixel_x_size + h) * n+2] = pixel[w * pixel_x_size + h].blue;
					odata[(w * pixel_x_size + h) * n+3] = pixel[w * pixel_x_size + h].alpha;
			// write jpg
			stbi_write_jpg(filePath.c_str(), ow, oh, n, odata, 100);
			stbi_image_free(odata);
		delete[] pixel;
2 REPLIES 2
sxs
@Ralph Wessel
        API_Component3D	mat = {};
	mat.header.typeID = API_UmatID;
	mat.header.index = iumat;
	auto err = ACAPI_ModelAccess_GetComponent(&mat);
	if(err != NoError)
          return;
        delete mat.umat.mater.texture.fileLoc;//this is texture location in embedded library
	mat.umat.mater.texture.fileLoc = nullptr;
Hello,I already know the path of the texture in embedded library. Is there a way to directly copy it from the library?
I found your answer in another post, but that method is not suitable for me.
https://community.graphisoft.com/t5/Archicad-C-API/How-to-get-the-path-of-texture/m-p/261656#M2314
Solution
sxs
	if (err != NoError)
		return;
			continue;
			continue;
		//save bitmap
			int n = 4;
			// write jpg
		delete[] pixel;
