Archicad C++ API
How to create a ListBox with dragable/movable (drag & drop) item?
ReignBough
I am creating a dialog with list box. The items should me dragable/movable to any row. I am using ListBoxObserver but I am unable to do it.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Oleg
There is 2 way
1. Full Drag-Drop
Call the EnableDragAndDropEvent() for panel (dialog)
Implement Drag-Drop handlers of the ListBoxObserver (ListBoxDragSourceObserver, ListBoxDropTargetObserver), at last
ListBoxDragStarting, ListBoxDragStarted, ListBoxDragEntered, ListBoxDragMoved, ListBoxDropped
2. Simple row dragging
Create an "drag" icon column. Fill it the DG::ListBox::DragIcon or any other.
Call list.EnableMouseMoveEvent() for the list box
Implement ListBoxMouseMoved( const DG::ListBoxMouseMoveEvent& ev, short* inArea );
When a mouse will be over the drag icon column, assign *inArea = DG::ListBox::DragArea.
Implement ListBoxItemDragged( const DG::ListBoxDragEvent& ev ) to handle dragging
Oleg
There is 2 way
1. Full Drag-Drop
ReignBough
Thank you.
The error in my code was in ListBoxMouseMoved() function since I follow the documentation:
virtual void ListBoxMouseMoved (
    const ListBoxMouseMoveEvent & ev,
    bool *              inDragArea
It is now working after I changed it to short.
~ReignBough~
