How to create checkbox column in listview
Hi
I have a listview in my dialog.
I need a checkbox column in my listview in order user can select a few items.
Is there a way to do that ?
Thanks in advance.
8 Replies 8
Ralph Wessel
There are 2 possible ways to do this:
  • 1) Use DGListSetDialItemOnTabField to place a check box control in the list column;
    2) Use check-box icons placed in the relevant column and watch for a DG_MSG_CLICK message to toggle the icon between checked and unchecked. The documentation for this can be found in the same place as DGListSetDialItemOnTabField. This is the recommended solution.
Ralph Wessel BArch
Central Innovation
Thank you for the help.
I have 2 questions:
(1) I am trying to put a column of checkboxes into my listboxes...
Currently doing something like:
DGListSetDialItemOnTabField ( IDD_BACKSYNC, GetListIDFromDialog( pEntry->GetEntryType() ), 2, DG_LIST_UNCHECKEDICON );
IDD_BACKSYNC is the id of the dialog.
GetListIDFromDialog( pEntry->GetEntryType() ) returns an enum of the listbox that is the same value as in .grc file.
2 is the 2nd column.
but not seeing any checkbox.
Seems like I'm doing this incorrectly.
(2)
// THIS LINE WILL CREATE A BLACK, when it should be red.
DGListSetTabItemBackgroundColor ( IDD_BACKSYNC, GetListIDFromDialog( pEntry->GetEntryType() ), DG::ListBox::BottomItem, 1, 255, 0, 0 );
'GDLG'  32505  Modal				337  259 800	600  "Sync From Fuzor To ArchiCAD" {
/* [  1] */ Button					 36  543   100   30	LargePlain  "Select All"
/* [  2] */ Button					200  543   100   30	LargePlain  "Select None"
/* [  3] */ Button					350  543   100   30	LargePlain  "Sync Selected"
/* [  4] */ Button					515  543   100   30	LargePlain  "Exit"
/* [  5] */ SingleSelList			 10  20    760   100	LargePlain  PartialItems VScroll 18 HasHeader 18
/* [  6] */ SingleSelList			 10  120   760   100	LargePlain  PartialItems VScroll 18 HasHeader 18
/* [  7] */ SingleSelList			 10  220   760   100	LargePlain  PartialItems VScroll 18 HasHeader 18
/* [  8] */ SingleSelList			 10  320   760   100	LargePlain  PartialItems VScroll 18 HasHeader 18
/* [  9] */ SingleSelList			 10  420   760   100	LargePlain  PartialItems VScroll 18 HasHeader 18
class BackSyncDialog : public DG::ModalDialog,
						   public DG::ButtonItemObserver
	public:
		BackSyncDialog ( std::vector<BackSyncBaseTask*> &syncEntries );
		~BackSyncDialog ();
	// Results after running modal dlg
	public:
		void FillData(std::vector<BackSyncBaseTask*> &syncEntries );
	protected:
		DG::Dialog& GetReference ()
			return *this;
		std::wstring GetHeader ( BackSyncTaskType );
		short GetListIDFromDialog ( BackSyncTaskType );
		DG::SingleSelListBox & GetParentListByEntryType ( BackSyncTaskType a_eEntry );
	private:
		enum {
			BtnSelectAllId = 1,
			BtnSelectNoneId = 2,
			BtnSyncSelectedId = 3,
			BtnExitId = 4,
			LstViewFamilyPlacementId = 5,
			LstViewObjectRefitId = 6,
			LstViewDeletionId = 7,
			LstViewMaterialSwitchId = 8,
			LstViewMaterialPropertyId = 9
		DG::SingleSelListBox	FamilyPlacementList;
		DG::SingleSelListBox	ObjectRefitList;
		DG::SingleSelListBox	DeletionList;
		DG::SingleSelListBox	MaterialSwitchList;
		DG::SingleSelListBox	MaterialPropertyList;;
	void BackSyncDialog::FillData(std::vector<BackSyncBaseTask*> &syncEntries )
		static const int c_dwNumFields = 4;
		static const int c_COLOR_STATUS = 30;
		static const int c_CHECK_FIELD_WIDTH = 30;
		static const int c_NAME_WIDTH = 200;
		static const int c_DESCRIPTION = 300;
		for ( short i = 0; i < BackSync_Max; i++ )
			DG::SingleSelListBox & group = GetParentListByEntryType ( (BackSyncTaskType)i );
			group.SetTabFieldCount(c_dwNumFields);
			group.SetHeaderSynchronState ( false );
			short pos = 0;
			group.SetTabFieldProperties(1, pos, pos + c_COLOR_STATUS, DG::ListBox::Left, DG::ListBox::EndTruncate, true, true);
			pos += c_COLOR_STATUS;
			group.SetTabFieldProperties(2, pos, pos + c_CHECK_FIELD_WIDTH, DG::ListBox::Left, DG::ListBox::EndTruncate, true, true);
			pos += c_CHECK_FIELD_WIDTH;
			group.SetTabFieldProperties(3, pos, pos + c_NAME_WIDTH, DG::ListBox::Left, DG::ListBox::EndTruncate, true, true);
			pos += c_NAME_WIDTH;
			group.SetTabFieldProperties(4, pos, pos + c_DESCRIPTION, DG::ListBox::Left, DG::ListBox::EndTruncate, true, true);
			pos += c_DESCRIPTION;
			GS::UniString header( GetHeader((BackSyncTaskType)i).c_str());
			DBPrintf ( "Setting header for: %ls\n", header.ToUStr().Get());
			group.SetHeaderItemText ( 1, header );
		for ( int i = 0; i < syncEntries.size(); i++)
			BackSyncBaseTask *pEntry = syncEntries.at(i);
			DG::SingleSelListBox & group = GetParentListByEntryType( pEntry->GetEntryType() );
			group.AppendItem();
			GS::UniString name( pEntry->GetEntryName().c_str() );
			GS::UniString description ( pEntry->GetEntryDescription().c_str());
			group.SetItemValue(DG::ListBox::BottomItem, reinterpret_cast<DGUserData>(pEntry));
			// GetLIstIDFromDialog will return LstViewFamilyPlacementId ... LstViewMaterialPropertyId
			// THE BELOW LINE DOESN'T SHOW A CHECKBOX WITH UNCHECKED ICON.
			group.SetTabItemText(DG::ListBox::BottomItem, 3, name );
			group.SetTabItemText(DG::ListBox::BottomItem, 4, description );
			DBPrintf ( "%d: name:%ls desc:%ls\n", i, name.ToUStr().Get(), description.ToUStr().Get());
Ralph Wessel
IanTr wrote:
I have 2 questions:
(2) // THIS LINE WILL CREATE A BLACK, when it should be red.
1) DG_LIST_UNCHECKEDICON is the index of an icon resource, so you should apply it to a list with DGListSetTabItemIconId.
2) Try using DGListSetItemBackgroundColor.
Ralph Wessel BArch
Central Innovation
Oleg
As you use a class library dialog, there are class member functions.
1. SetOnTabItem, RemoveOnTabItem
2. SetTabItemIcon
Like this:
// Check Icon State
mi_split_list.SetTabItemIcon( item, CHECK_FIELD, DG::Icon(on ? ListBox::CheckedIcon : ListBox::UncheckedIcon) );
// Click handler
void TabAlgoSplit::ListBoxClicked( const DG::ListBoxClickEvent& ev )
	if ( ev.GetSource() == &mi_split_list )
		short pos = ev.GetMouseOffset().GetX();
		short beg = mi_split_list.GetTabFieldBeginPosition( CHECK_FIELD );
		short end = mi_split_list.GetTabFieldEndPosition( CHECK_FIELD );
		if (  pos > end || pos < beg )
			return;
		OnSplitCheckClicked( ev.GetListItem() );
Hello,
Thanks you for the suggestions.
I end up doing something like this in the Dialog's contructor to put checkboxes in listboxes row. Currently the checkboxes showed up in Archicad18...20. But it DOESN'T show up visually in archicad21. However, functionally
everything, is working i.e. in ListBoxClicked when I query whether the checkbox was checked or not, it will return the correct state. I was just wondering if I needed to do something in Archicad 21 to get the checkbox to show?
I printed out resId & resModule between Archicad 19 & 21 and they matched.
resId of -4 is enum for DG_LIST_UNCHECKEDICON
- icon {...} const DG::Icon &
- DG::Image {resModule=8790715924480 resId=-4 data=0x0000000000000000 } DG::Image
+ __vfptr 0x000007fed2a5ff68 *
resModule 8790715924480 __int64
resId -4 short
data 0x0000000000000000 const void *
DG::Icon icon(ACAPI_GetOwnResModule(), DG_LIST_UNCHECKEDICON );
	group.AppendItem();
	group.SetTabItemIcon (DG::ListBox::BottomItem, ROW_CHECK_FIELD, icon );						// Set the icon works in Archicad18 ... 20
	group.SetTabItemText(DG::ListBox::BottomItem, ROW_NAME, name );
	group.SetTabItemText(DG::ListBox::BottomItem, ROW_DESCRIPTION, description );
	void BackSyncDialog::ListBoxClicked (const DG::ListBoxClickEvent & ev)
		short dwListItem = ev.GetListItem();
		DG::ListBox *pListBox = ev.GetSource();
		if ( pListBox )
			short begCheckBox = pListBox->GetTabFieldBeginPosition( ROW_CHECK_FIELD );
			short endCheckBox = pListBox->GetTabFieldEndPosition ( ROW_CHECK_FIELD );
			if ( pos > begCheckBox && pos < endCheckBox )
				DG::Icon myIcon = pListBox->GetTabItemIcon ( dwListItem, ROW_CHECK_FIELD );
				bool bWasChecked = ( myIcon.GetResourceId() == DG_LIST_CHECKEDICON ); // This shows if checked/unchecked even if the checkbox can't be seen in 21.
				const DG::Icon & icon = DG::Icon(ACAPI_GetOwnResModule(), bWasChecked ? DG_LIST_UNCHECKEDICON : DG_LIST_CHECKEDICON );
				pListBox->SetTabItemIcon ( dwListItem, ROW_CHECK_FIELD, icon );
Oleg
Unfortunately, I dont know.
I have no AC21 environment on this workplace for tests.
Oleg
On AC21.
Try the "SysResModule" instead ACAPI_GetOwnResModule(), like this:
#include "RSTypes.hpp"
DG::Icon( SysResModule, ListBox::UncheckedIcon)
