Sun direction documentation
Hey All,
I think that the documentation for APIAny_CalcSunOnPlaceID is bad, since API_PlaceInfo has been changed.
I try to figure out how does it work now, but I have some troubles. Could you please help?
double getSunDir (void){
	API_PlaceInfo  placeInfo;
	API_Attribute  attrib;
	GSErrCode      err;
	BNZeroMemory (&attrib, sizeof (API_Attribute));
	attrib.header.typeID = API_CityID;
	CHCopyC ("Budapest", attrib.header.name);
	err = ACAPI_Attribute_Search (&attrib.header);
	if (!err) {
		BNZeroMemory (&placeInfo, sizeof (API_PlaceInfo));
		placeInfo.timeZone = attrib.city.zone;
		placeInfo.latitude = attrib.city.latitude;
		placeInfo.longitude = attrib.city.longitude;
		DBPrintf("latitude %d",placeInfo.latitude);
		DBPrintf("longitude %d",placeInfo.longitude);
		placeInfo.sumTime = false;    // winter time
		placeInfo.dayOfYear = 60;
		placeInfo.minOfDay = 600;
		placeInfo.north = PI / 2;     // up direction
		err = ACAPI_Goodies (APIAny_CalcSunOnPlaceID, &placeInfo, NULL);
		return placeInfo.sunAngXY;
	else{
	DBPrintf("We don't know where the sun is.");
	return 0;
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Szia Andor,
I will fix the documentation for APIAny_CalcSunOnPlaceID.
Here's an example code from Environment_Control test AddOn:
// Get city/date/time/sun information
static void		Do_DumpLocation (void)
	API_Vector3D	sunDir;
	GSErrCode		err;
	err = ACAPI_Environment (APIEnv_GetPlaceSetsID, &placeInfo, NULL);
	if (err) {
		ErrorBeep ("APIEnv_GetPlaceSetsID", err);
		return;
	WriteReport ("actual day: %d", placeInfo.dayOfYear);
	WriteReport ("actual minute: %d", placeInfo.minOfDay);
	placeInfo.dayOfYear = 45;
	placeInfo.minOfDay = 8 * 60 + 45;
	if (err) {
		ErrorBeep ("APIAny_CalcSunOnPlaceID", err);
		return;
	sunDir.x = cos (placeInfo.sunAngXY) * cos (placeInfo.sunAngZ);
	sunDir.y = sin (placeInfo.sunAngXY) * cos (placeInfo.sunAngZ);
	sunDir.z = sin (placeInfo.sunAngZ);
	WriteReport ("Sun data at 8:45 on 14th February");
	WriteReport ("  xy angle: %lf", placeInfo.sunAngXY);
	WriteReport ("  z angle:  %lf", placeInfo.sunAngZ);
	WriteReport ("  dirVect:  (%lf, %lf, %lf) ", sunDir.x, sunDir.y, sunDir.z);
	return;
}		// Do_DumpLocation
This shows how to calculate the sun direction from the given placeInfo.
Best Regards,
Tibor
Ran into the incorrect documentation also.
I was wondering if there is a way to pull out the current selected city in the sun directoin in Archicad 19
