Archicad C++ API
How to create menu on one level with "File", "Edit" etc?
My .grc file has next content:
'STR#' 32500 "Strings for the Menu" {
/* [   ] */     "Menu name"
/* [   1] */	    "item 1"
/* [   2] */	    "item2"
and menu was placed as submenu of "Options".
How can I move my menu one level up? What can I do with "32500" number?
Thanks
5 REPLIES 5
equilibrium wrote:
...menu was placed as submenu of "Options".
You can specify the menu position with the APIMenuCodeID passed with the call to ACAPI_Register_Menu. If I understand your intentions correctly, I think you want MenuCode_UserDef.
Ralph Wessel BArch
Central Innovation
You are right, Ralph. Thanks
I was moved my menu on top level and now have next menu:
MyMenu
`SubMenu
``SubSubMenu1
``SubSubMenu2
``SubSubMenuN
But I want to create menu like this:
MyMenu
`SubMenu1
`SubMenu2
`SubMenuN
One way - it's creation of N 'STR#' sections in my .grc file like this:
/* [   ] */     "MyMenu"
/* [   1] */	    "SubMenuN"
Than register them all and use own MenuHandler for each SubMenu.
But it's unwieldy way - I should to create new MenuHandler when add new SubMenu anytime.
Can you suggest more acceptable way? Thanks
equilibrium wrote:
I was moved my menu on top level and now have next menu: One way - it's creation of N 'STR#' sections in my .grc file like this:
/* [   ] */     "MyMenu"
But it's unwieldy way - I should to create new MenuHandler when add new SubMenu anytime. Can you suggest more acceptable way? Thanks
No - that's the way it works.
Ralph Wessel BArch
Central Innovation
It's really bad to create own description in .grc file for each first level submenu item.
Thanks a lot, Ralph
