2023-10-21
07:44 AM
2024-09-16
02:38 PM
Doreena Deng
hi guys,
Do you know how to get active view?
(I think I need to use API_NavigatorItem, But I couldn't do it)
If you know, please help me
Thank you very much
2023-10-24 11:14 PM
There's no function to get the active view directly as far as I know.
But you can workaround this with using with a View Notification Handler.
You have to register the notification handler in the Initialize function:
ACAPI_Notify_CatchViewEvent (APINotifyView_Opened, API_MyViewMap, ViewNoticationHandlerProc);
This has to be done separately for every API_NavigatorMapID you need. So you'll have to use a bit of trial and error to figure out which ones you'll need.
And the handler would look something like this:
static GSErrCode __ACENV_CALL ViewNoticationHandlerProc (const API_NotifyViewEventType* viewEvent)
switch (viewEvent->notifID) {
case APINotifyView_Opened: {
// Do something here with `viewEvent->itemGuid`
break;
default: break;
return NoError;
Also the Add-On needs to be registered as a preloaded Add-On. So return API_Addon_Preload in CheckEnvironment.
Hope that helps!
Bernd
2023-10-30
02:39 AM
2023-10-30
03:52 AM
Hi @Bernd - Archi-XT ,
I followed your tutorials, but it still doesn't work? Can you check and tell me where I'm wrong
This is my code:
API_AddonType __ACENV_CALL CheckEnvironment(API_EnvirParams* envir)
RSGetIndString(&envir->addOnInfo.name, ID_ADDON_INFO, 1, ACAPI_GetOwnResModule());
RSGetIndString(&envir->addOnInfo.description, ID_ADDON_INFO, 2, ACAPI_GetOwnResModule());
return APIAddon_Preload;
static GSErrCode __ACENV_CALL ViewNoticationHandlerProc(const API_NotifyViewEventType* viewEvent)
WriteReport_Alert("View");
break;
default: break;
return NoError;
GSErrCode __ACENV_CALL Initialize(void)
GSErrCode err = ACAPI_Install_MenuHandler(ID_MENU_STRINGS, MenuCommandHandler);
API_NavigatorMapID mapId = API_MyViewMap;
ACAPI_Notify_CatchViewEvent(APINotifyView_Opened, mapId, ViewNoticationHandlerProc);
if (err != NoError)
DBPrintf("3D_Test:: Initialize () ACAPI_Install_MenuHandler failed\n");
return err;
} // Initialize
2023-10-31 10:35 AM
Hi @Bernd - Archi-XT , Can you help me?
2023-10-31 10:40 AM
I'm quite busy right now, but tomorrow I'll have more time to take a closer look.
Please specify what exactly is not working.
What did you try to do in the program and what did you expect to happen?
From a quick look at the code it seems OK. Maybe try different NavigatorMapIDs like API_ProjectMap, API_UndefinedMap, API_PublicViewMap.
2023-11-04 09:58 AM
I did a few quick tests by opening different view maps in Archicad and checking which map ID is used in the triggered view notification.
Here's the mapping of Archicad Navigator Map -> API_NavigatorMapIDs when listening to APINotifyView_Opened:
Couldn't find anything that triggered the API_MyViewMap. I'm sure I used it before for something, but can't remember now.
Hope that helps,
Bernd
