Archicad C++ API
How to get elements list in 3D slab.
nishida_jp
I created a slab polygonal prism in 3D.
I would like to get the Guids of parts in multiple slabs in order to use ACAPI_Element_SolidLink_Create(),
but how can I do this?
Parts inside the slab will be retrieved,
including those that extend beyond the slab.
I cannot use 'bounds' because there are diagonal parts.
1 REPLY 1
LChen
Sorry, I'm not so clear what your problem is. If you'd seek (judge) whether a slab is inside or outside of another polygon (prism), then it's a geometry matter. I'm afriad you cannot find a single command which can do with API.
