Archicad C++ API
How to get only shown elements in C++?
HKM
ACAPI_Element_GetElemList(API_ZombieElemID, &elemList, APIFilt_OnVisLayer);
This gets all elements on the visible layer.
I want to exclude elements hidden by F5 key or 3D filters or else.
Archicad26 Windows10 APIDevKit 26.3000
notes)want other methods other than send [ctrl+A].
Viktor Kovacs
You can use several filter options. In your case you probably need the APIFilt_In3D filter. So the call would look something like this:
ACAPI_Element_GetElemList(API_ZombieElemID, &elemList, APIFilt_OnVisLayer | APIFilt_In3D);
Viktor Kovacs
Thank you.
This worked as expected.
For some reason 'APIFilt_In3D' was convinced that it was useless.
