How to get thumbnail and parameters from external library part?
Hi everyone,
i'm tried from figure out to get thumbnail and parameters from external library part but failed.
For example :
	IO::Location fileLoc("C:\\Users\\W.C.SHIM\\Downloads\\test.gsm");
	API_LibPart      libPart;
	BNZeroMemory(&libPart, sizeof(API_LibPart));
	libPart.typeID = APILib_ObjectID;
	libPart.location = &fileLoc;
	ACAPI_LibPart_Register(&libPart);
but it doesnt work :'(
so... can i do this?
7 Replies 7
Ralph Wessel
The quoted code should register the library part with ARCHICAD as part of the loaded library. Does that work, i.e. does it return NoError and is libPart.index non-zero?
If so, use the returned index to call ACAPI_LibPart_GetSectionList. The parameters, scripts and preview image are all stored in the returned sections. Each section has an ID for the data it contains, e.g. the parameters ID is API_SectParamDef and the preview image is API_SectInfoGIF.
Ralph Wessel BArch
Central Innovation
oooo... my mistake :'( i want load a .gsm file. not use part of the loaded library
(just open and use gsm file programmatically)
i tried ACAPI_LibPart_Create and ACAPI_LibPart_Register. but libpart.index is always 0.
Ralph Wessel
ACAPI_LibPart_Register effectively includes the gsm in the loaded library – you can't work with it otherwise. The value of libpart.index is the object's index in the loaded library.
Do you get an error code returned from ACAPI_LibPart_Register?
Ralph Wessel BArch
Central Innovation
I tried this :
	GSErrCode err = NoError;
	err = ACAPI_LibPart_Register(&libPart);
	if (err != NoError)
		char msgStr[256];
		sprintf(msgStr, "Register Error : %d", (int)err);
		ACAPI_WriteReport(msgStr, true);
	err = ACAPI_LibPart_Create(&libPart);
	if (err != NoError)
		char msgStr[256];
		sprintf(msgStr, "Create Error : %d", (int)err);
result is
Register Error : -2130313214
Create Error : -2130312314
I tried to find the error code but i can't find :'(
Ralph Wessel
Twily wrote:
result is
That error is APIERR_MEMFULL (Insufficient memory), which is odd. In what context are you trying to register the library part, e.g. in response to a menu item click?
Ralph Wessel BArch
Central Innovation
Ralph wrote:
Twily wrote:
result is
yes, i'm testing to menu item click.
But later i will use immediately after open archicad.
I want this method (in automatically) :
after open archicad (load addon) ->
load gsm file ->
get thumbnail and parameters ->
close gsm file.
Ralph Wessel
load gsm file ->
close gsm file.
That code should work in the right context – it looks practically identical to the documentation example. Perhaps try building one of the example projects – LibPart_Test – that uses this function. See if it works in that context and work back from there.
Ralph Wessel BArch
Central Innovation
