‎2018-02-14
08:21 AM
- last edited on
‎2023-07-12
05:49 PM
by
Doreena Deng
Solved! Go to Solution.
‎2018-03-06 05:03 PM
‎2018-03-16 04:49 AM
MOREH wrote:It is ok, thanks a lot
you can get Operation Profile's values using the ACAPI_Attribute_Get method, when you set the attributes header.typeID as API_OperationProfileID.
Have you seen the API_OperationProfileType in the doc? Do you need something which cannot be found?
