Is there any way to get data from Energy Evaluation Module?
I want to get data from Operation Profile that the user enter to do some calculation in my addon, is there any way to do that?
1 Solution
MOREH Tamas
you can get Operation Profile's values using the ACAPI_Attribute_Get method, when you set the attributes header.typeID as API_OperationProfileID.
Have you seen the API_OperationProfileType in the doc? Do you need something which cannot be found?
Go to post
2 Replies 2
MOREH Tamas
It is ok, thanks a lot
