Lingwisyer
Guru
GDL: Surface Override Parameter
Hi all,
Is there some way to access and write back to the Surface Override Parameter?
I have ways to override surfaces within my object and I was wanting to link this parameter rather than have it be seperate and override the internal overrides.
So the first internal override would be reflected to the external one. And ideally the toggle would be too.
IF GLOB_MODPAR_NAME = "[gs_boverride]" then
	mat_over1 = [gs_boverride]
	mat_1 = [gs_override]
	PARAMETERS [gs_boverride] = [gs_boverride]
	PARAMETERS [gs_override] = [gs_override]
endIF
IF GLOB_MODPAR_NAME = "mat_over1" then
	[gs_boverride] = mat_over1
	[gs_override] = mat_1
	PARAMETERS mat_over1 = mat_over1
	PARAMETERS mat_1 = mat_1
endIF
Ling.
I know SYMB_MAT is the material for the override, but I am not sure if you can determine if the override is active or not.
